DAGE
- Nov 8, 2005
- where the snows at
- Other
- 06 Attak
I emailed Yamaha Canada today because I'm fed up of my sled cutting out and wanted to update my float bowls, I was surprised to hear they no longer carry the updated bowls and their solution was to buy used carbs from an 04-05 RX-1 to fix my problem
I thouht they would've had as many kits as there were 03 RX-1 MTN's but I guess I was wrong
Kyle
Kyle
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
try the us if you have the part# i check to see if is availble and can help you get one if needed let me know
bdm
those have been tough to find for a few years now. Used will probably be your only option.
SRXSRULE
They got sold to other owners too. I got a set under warranty for my 04 Warrior but that was like 5 years ago. Eric
DAGE
- Nov 8, 2005
- Other
- 06 Attak
I found this after a quick search
part # 8ep-1111t-00
testing parts-rx10mh/msh carburetor float bowl kit
kit contents
4-float bowls
4-main jet holders with two o rings each
part # 8ep-1111t-00
kit contents
4-float bowls
