no start!!
yukon yamaha
WHITEHORSE, YUKON CANADA
Canada
2008 nytro custom! 2014 viper custom
I just pulled my machine into the shop and she is stone dead... So first i switched out the battery, wrong the battery had loads of charge..... i checked the ighnition switch all is good, so the problem still stands, when i turn the key on nothing happens i mean nothing no lights no noises nothing lol has anyone else had this proplem? or know how to fix it?
All help is welcome !
thanks guys! :Rockon:
normal stuff to check are the kill switch, fuses, ignition switch connector for corrosion (should check all connectors periodically as preventive maintenance) and relays (load control has been problematic).
http://www.ty4stroke.com/viewtopic.php?t=83992
