Noise/Vibration when coming to a stop?
blackattak
SouthEast N.B. Canada
I may just be hearing things but sled seems to be working very good BUT when I slow down to stop there seems to be a slight vibration/noise coming from the front of the track. I will be running along a trail speeds & when I come to the interestion to stop & take the thumb off the throttle just as the sled comes to the stop, with the last turn of the track there seems to be a slight rumble/vibration.
I may just be nervous because of the electrical gremlin I had this season & it may be perfectly normal ! The dealer has adjusted the chain case, suspension & tightened the track this past week & was just noticing this yesterday.
Anything to worry about or check? About 10,500 km or 6500 miles on the sled.
bearing
You should check your driver bearing on the secondary clutch side for cracks. I just had that same feeling and that is what it was.
Took it to the dealer. They checked the secondary bearings, drive shaft bearings etc & all look fine & were greased. The also checked the chain case, readjusted the track & everything looks fine.
Maybe I was just hearing things. Will pick it back up Wednesday. Better safe than sorry I guess...
