Illiniyami
Guys, I have a 2011 Apex xtx with 2900 miles I bought used in january. I only got to really put some miles on it 1 weekend and noticed the the primary was very loud sometimes (not squeeking more of a rattle) mostly at idle to about 30 mph is this normal? Are there bearings in the primary? Any thoughts, suggestions? Sled stock as far as I was told other than studs, big wheel kit and hid's, thanks
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
have the clutches ever been cleaned? i would start there
Illiniyami
I cleaned them both when I got the sled with simple green and water also cleaned the brand new belt the same way
judger101
its a common thing, my nytro is quite loud especially with all the foam out.
judger101 said:its a common thing, my nytro is quite loud especially with all the foam out.
The 3cyl motors have a bad rattle in the primary. The Apex primary shoud be very quiet. Look for loose weights or rollers
judger101
oops sorry
Illiniyami
Thanks I will check into those
