scottydog1
Are there supposed to be O-rings @ the pivot pt of you primary clutch arms. It seems to be quite loud and rattley while @ idle. I looked @ the arms and they slide very easily (sloppy) on the rod that holds that hold the (3) arms to the primary. Other than the noise i absolutely love this sled! My 05 Warrior doesn't make any where the noise (rattle) that my FX Nytro does? Any suggestions? Or should i not worry about it?
scottydog1
ttt
nytrortx149
I have the same noise. I hope they come out with a kit to fix this. They had a kit for my 05' vecter and it worked great after I put it in. You don't have to worry about it though its just loud.
scottydog1
I agree its just loud and little annoying. I don't like squeeks or rattles in my vehicles, so this just annoys me to no end. As for the performance of the sled, you all know it is awesome!!! What was the kit they offered for the Vector? Is it o-rings?
Turk
Tech Advisor
Totally 100% natural & won,t hurt a thing. My turbo rX-1 was worse. The nytro clutch even gets way noisier when u install aftermarket weights.
nytro24
Agree 100% also, seems to be the nature of the beast. Would not worry about it!
nytrortx149
yes it was just o-rings.
scottydog1
Thanks to all I guess I will have to deal w/ it.
nytro23
- May 18, 2007
- wasilla, alaska
- www.nytro23.com
not to worry
Nothing to worry about. Factory Yamaha had us remove O rings
from our sleds on last years race. There was a slight chance that
the O rings would actually cause some friction or sticking. So we
removed them, put up with the noise won't hurt a thing. But it makes
you wonder why they build such a nice sled with great engineering
and why can't they make a clutch that is quiet like everyone else has
for the last 50 years????
Kråkan
If I have to make a guess. Yam has had this system a LONG time.. Maybee because they are waiting to release something NEW... Totally different when the market is ready??
phazerman2000
Re: not to worry
no other makes have had a three cylinder four stroke to try their clutches on. also it is the sliding arms not the weight arms that are making all the racket. install a yamaha damper kit part # 8es-slidr-kt-00 and the noise will be gone.
nytro23 said:Nothing to worry about. Factory Yamaha had us remove O rings
