Not a good start to my new sled
race24x
Belgrade, Maine
Website
www.r-scomputer.com
I have an 07 RTX and already I have some issues. My mods are as listed. Ram air airbox Hauck Fuel accelerator Hauck helix Hauck exhaust CR10EK's. It wont idle if you blip the throttle it wont idle at all and stalls. After you start it back up it idles fine. I just took it for a little spin and it seems horrible.
fuel
sounds like your fuel accelerator needs to be adjusted, call pat hauck at
1- 715- 634- 6195
Did you just install the fuel accelerator? If so I would agree with the guys about the accelerator. If not, check the throttle body boots. I had the same condition and I found one of my boots wasn’t on correctly. It may also be the throttle position sensor.
I will try Hauck and see what he says. I did add the Ram Air kit and the CR10EK plugs cause my sled fouled the plugs. I was wondering about the whole drive it for a while thing for the computer block learn. Like on GM cars we would have to drive them a bit for the O2 sensor to get the block learn in the right range.
I called Haucks and they where a great help. Told me over the phone the baseline setting as I have added the Ram Air and walked me through how to set it. I love places that are willing to talk to a regular user and get you going. We will see if that helps later today. Damn work getting in the way of all my fun.
OK its really starting to suck. I changed all of the settings to Haucks recommendations and the friggin thing still wont idle. I cant beleive a newer sled runs worse than my old RX1. I am going to check it out for the throttle body issue as mentioned, but I guess I will have to take it to the dealer it is under warranty. I will see if I can get a first ride in on this thing
Try running some fuel injector cleaner through it and how new are these plugs again?
Also, is your belt squeeling?, and how does the belt sit in your secondary? If its too tight, it will cause your rpms to drop and stall the sled out.
Thanks there is some more to check I didnt even think about that. It would explain the fact if you restart it it idles fine and if you go to move it and stop again it stalls. The plugs are brand new and it seems to start and idle fine until I go for a ride.
First unhook, the Fuel excellerator and see how it reacts. Even if you have an exhaust it should idle fine. You may also had a bad plug from the get go..
Also, as mentioned above if you belt is to tight, it may stall or idle right down, since there is a drag on the motor..
Please don't take this the wrong way---------------------------------------------------------------"BUT" who's the beautifull blond?????????? She's perfect.. MM. ;)!
That is Doutzen Kroes a Victoria's Secret model. She is from Friesland, Netherlands and in my opinion she is absolutely stunning.
OK I checked the clutch and the boots they seem fine. I think the problem is the Fuel Accelerator. The light is on green for a little whiel then it starts blinking green red and thats when it starts actng up. I just bought the sled used so I am going to ask the dealer first they are pretty decent guys. If that doesnt work I will call Pat Hauck again to see what sort of warranty they have
Just wondering if anyone else has had this trouble with the Fuel accelerator. Checked my buddies and he said his is green all the time, it doesnt blink red green
wont run
did you try the sled with the fuel mod disconected.did it then run better?
you said you called pat hauck,and he told you how to adjust it,have you changed the settings,if not,try adjusting the green setting MORE.
is there water in your fuel,fouled plug.
i have the same accelerater,pod filters,and excell exhaust(and some light weght mods,and it will run without the fuel excellerater(dont do it too long)just disconect it and see if it runs better.
good luck D
