THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Have you tried the Gia maps appIt’s an iPad mini 5. It was just an experiment but it works well. The biggest problem with an android or IOS tablet is both brightness and simultaneously contrast, especially color contrast for image based maps and some map apps (ofsc). Garmin has does this well with superior map contrast. Having said that what makes it look big is the casework and bezel. The screen is just under 8” measured on the diagonal.
I’m intrigued by this
earthling
Not yet but it is on my list as well as trackmapsHave you tried the Gia maps app
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
- ramody44@yahoo.com
Really? I called back in January and they didn't and he didn't make it sound like it was coming. Is there and way to switch tunes as well, and to know which HP you are running?they do now.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
From their site......Really? I called back in January and they didn't and he didn't make it sound like it was coming. Is there and way to switch tunes as well, and to know which HP you are running?
Latest Update:
January 16th, 2023
-Adds support for the profile based suspension control in 2020+ Arctic Cat sleds with electronic suspension.
-Adds support for changing the suspension setting on Arctic Cats with electronic suspension via the Mode button on the handlebars.
-Move the suspension setting from the Vehicle Settings dialog to a new Suspension Settings dialog.
-Fix an issue with the odometer occasionally resetting to zero on some gauge systems.
-Fix an issue with the Vehicle Settings dialog having a Next button instead of a Done button when editing a field.
Download NS1Dashboard_1-16-2023.apk
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
Ok, Thank youFrom their site......
Latest Update:
January 16th, 2023
earthling
I got the same message from him right at the end of last year. I guess enough people asking and there you go. Looks like a real contender for me now.
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
I do notice it says Arctic Cat, and Not Yamaha. Different ECM's. Wondering if that's an issue. Have to call and verifyI got the same message from him right at the end of last year. I guess enough people asking and there you go. Looks like a real contender for me now.
earthling
The suspension is the same ECM is it not and the processing is in the gauge for IQs, not the main ECU? The ECM for the suspension is an addon as far as I can tell, it just uses the gauge to both display the current mode and to translate the canbus messages. It makes sense from Stefans statement that he can process the mode button and send the appropriate commands. Stefan owns or did own a Cat, but all of his gauge tech works on either.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
sounds like I can use the NYSSA gps trail map on this also if I wanted that up as my gps correct?
Skurtenb
This is exactly what I’m going to setup this summer. What did you use for the mount?Stain was asking what the ofsc app is. I run it for local trails on a custom ipad mini mount.
earthling
The ‘holder’ is an iPad holder for a ram mount. The ram mount is attached directly to the door on the arctic cat dash caddy. The iPad is in a case and there are some aluminum plates that are cut to fit the backside of the case and they hold a heating element. I can document this in greater depth if you are interested but will move to a new thread.This is exactly what I’m going to setup this summer. What did you use for the mount?
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Back to this gauge again.
I see it does not support turn-by-turn navigation. Not having a GPS on a sled before, is this a big deal?
I compared the NS1 to a stand alone unit and the NS1 seems cheaper in the end.
I emailed the owner, but have yet to get a reply.....
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
I have one of these gauges and I have found the owner to be very helpful. The GPS function doesn’t work great in Ontario. I don’t need turn by turn Navigation personally so not an issue. I am not sure about trails in your area, but I purchased the trackmaps for Ontario, uploaded to Ns1 gauge and it shows all the trails but not the trail names. So kind of useless for me. I ran the split screen function this winter with the ns1 gauge and the Ontario snowmobile trails app. When it works it works well, but some days the trails app was very glitchy and would freeze often. I think this is an issue with the Ontario app and not the Ns1 gauge, because my gauge functions always worked perfectly. Only ever had issues with the OFSC app running.Back to this gauge again.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
We had some trouble last year on a saddlebag trip in Quebec and I am determined to get some sort of GPS this year to avoid the problem again.
I keep coming back to the NS1 gauge that I would then download GPS trail master's app on it.
For some reason I keep putting the purchase off.
I just bought a 12 gallon tank ($550) and will probably get a SMT 240 tune this year also ($500). The gauge and the GPS app would be another $800.
oh well
oh well
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
I love my NS1 on my 1100. Not sure about using it on my 22' Tcat. I put the cat based Garmin on the sled and it worked great. I do miss the big screen.
