Nut Fell off
Booster
Northern,NH
Right behind the clutch I noticed the nut was off and found it on the bottom of my bottom cover,Im assuming that this nut is for my motor mount?
Am I right?Any body else have this problem?
Do I have to tear everything apart to get to the back of this bolt?
I will definitely have to loctite it .
Not sure on the nut but I would investigate it. Where in NH are you. I live north of concord. Good luck
You can get a wrent on it from the upper part of the Side bulkhead casting. Yes that nut can come loose!!! It is the motor moutn nut
That one was in the steering update list.Loctite is your friend.Every nut and bolt you can get at.
