JP10
I was recently trying to take off the rear plastic on my Phazer, the piece which goes around the exhaust and under the sides of the seat. I got the seat off no trouble, and then the top 2 bolts out of the plastic, but then the bottom 2 bolts wouldn't come out, They spun freely in each direction. I never thought to see if I had to hold a nut on the other side, but all the other bolts are tapped into the frame or the nut is welded.
Does anyone know if There is indeed a loose nut at this location or is there any trick to get them out?
JP
JP
I had the same problem, and I cut the plastic in to those two bolts and got it loose.
Phazed-Coug
yeah the "insert" in the frame is spinning free
mine did that as well.. Kinda sucks, but hopefully won't have
to remove the plastics for anything
If they do that try tightening them before loosening.The tightening squeezes the nutsert tighter to frame so it doesnt spin.
I had one do that too... knocked them out and put in a rivnut.
Motoman765
- Dec 12, 2006
- Michigan
- www.teamfsr.com
Yea mine did the same thing. I just took the whole sub frame off with the exhaust to get under it.
