I'm sure someone has done this just can't find any posts. Stretching a 144 to a 153, do I need a tunnel extention and if so where do I find one. Have looked but so far no luck. Wondering if I even need to?
You could probably get away without one but I would probably get one. I would check out Hartman. I have seen extensions on the his website. Now as far as the skid goes I can't help you much as I have never stretched a Yammy. I think you will need to run smaller drivers to fit a taller lug track but I could be wrong. You just have to look and see how much room you have between you heat exhanger.
