crusen32
- Nov 2, 2014
- Sandy creek ny
- 2013 Yamaha nytro k&n intake,jardine slip on under tunnel exhaust, pc3
Hi i have a 13 nytro shorty that was 1-1/4 track that i stretched to 137” and 1-3/4 also have full exhaust k&n intake mostly all trail riding whats best clutch kits snd best gearing for this combo ??
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
I’d stick with the stock gearing, but lots to gain with clutching. Do you have any experience clutch tuning? I built my own kit with Dalton parts, but Ulmer racing has a bolt in and go kit with great adjustability if you’re not a clutch tuner. Thunder Products should also have a good setup. Both companies I’ve mentioned are site sponsors.
crusen32
- Nov 2, 2014
- Sandy creek ny
So stock gearing even though the longer track and no im not really familiar with clutch tuning i will check both of those manufacturers out
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
It really depends on where you use the sled the most. If it’s mostly off trail? Sure, drop a tooth up top. If it’s mostly on trail? Keep it. Factory Nytro gearing was already fairly low as is.
Zomboskid
- Oct 6, 2016
- Waukesha Wisconsin
- 18 Sidewinder BTX
86 SRV 540
I’ve got a Nytro MTX that I converted to a more trail friendly sled. We put XTX gearing in it and I had Thunder products clutch it, had no issues for 3 years and ~2500-3000 miles. Made the sled completely different from stock and really helped it, actually just had thunder products go through the clutches this summer and nothing was out of the ordinary.
Highly suggest Tim and Terry at thunder products!
crusen32
- Nov 2, 2014
- Sandy creek ny
I messaged them to see what they suggest thank you guysI’ve got a Nytro MTX that I converted to a more trail friendly sled. We put XTX gearing in it and I had Thunder products clutch it, had no issues for 3 years and ~2500-3000 miles. Made the sled completely different from stock and really helped it, actually just had thunder products go through the clutches this summer and nothing was out of the ordinary.
