yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
Does any one know if the nytro drive shaft on a non reverse nytro is the same as a normal nytro with reverse? The fisch shows the same part number but with a (-01) for all reverse nytros.... The 08 nytro doesnt have the (-01) and is back ordered..... Just hoping i dont have to change out my drive shaft to take my reverse off
Mountaintech
I did the same....got rid of reverse. You need the nut that threads onto the shaft (and maybe a washer...can't remember) to retain the bottom gear. Pretty sure the 01 shaft is the updated shaft that solves the broken bolt problem. Believe that updated shaft first surfaced in MY 2010.
yukon yamaha
- Jan 30, 2008
sweet! These are the parts i am lookin at ordering for the nonreverse chain case....
8ha-47543 cap, housing
93306-20468 BEARING
99009-47500 CIRCLIP
90170-22094 NUT
90208-22001 WASHER CONICAL
8DW-47587-91 NON REVERSE SPROCKET
90387-2508B COLLAR
93306-20468 BEARING
99009-47500 CIRCLIP
90170-22094 NUT
90387-2508B COLLAR
Mountaintech
I love the simplicity of the standard chaincase.
yukon yamaha
- Jan 30, 2008
I just dont use my reverse enough, so why not shed a few pounds of rotating mass....
Mountaintech
Yup, and ride knowing you don't have reverse. Never had it....and don't miss it.
- 7K
