wolfe9904
- Dec 29, 2013
Broke the pod up on my phazer and found a nytro one cheap will it work ???
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Only if you don't have reverse because it doesn't have a switch or the D and R lights since the Nytro has a manual lever mechanical reverse. I was looking for a pod for one of my Phazers and accidentally bought one for a non-reverse Phazer. I experimented with it and if you were to take the switch from the dead pod and solder it into the replacement pod, it would work but you would also have to do some other mods mods too and use your original cover if it's not broken. It's doable but a bit of work. For the lights, you could solder in some regular LEDs.
Or you could just solder in a small waterproof push button with wires and just screw it into the pod where the switch would be and forgo the lights.
Oh and you should add your location info. It's nice to know and it's a forum requirement.
RoicIND
I have a Phazer pod if you are looking. It has the reverse button
Ruggybuggy
- Sep 1, 2013
- Kenora, NWOnt, Canada
- 2007 Phazer FX 144
Also have one with reverse. Shoot me a PM with an offer.
