HOMEHARDWARE65
How hard is it to change the headgasket on a nytro. Also how long does it take.
thanks
thanks
09nytro
That must be it a . I think the eng. has to come out so i would say 4.0 hours maybe more
shadow44
Should be able to do it without removing the engine..just remove the gas tank, plastics, light pod and upper frame..
nytroman20
You'll have to remove the engine bolts and tilt the engine forward to access the chain tensioner.... Probably a total of 10 hours for the complete job!
HOMEHARDWARE65
called my dealer and they said you have to take off some motor mounts and rotate the engine to get to it. They said it would be about a 7.5 hour job.
09nytro
Thats what i thoughtHOMEHARDWARE65 said:called my dealer and they said you have to take off some motor mounts and rotate the engine to get to it. They said it would be about a 7.5 hour job.
Nine2Nine
HOMEHARDWARE65 said:How hard is it to change the headgasket on a nytro. Also how long does it take.
thanks
Did you find that to be the problem??
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Im thinking 6-8 hours depending how familiar you are with it.
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
thanks
How many miles are on the sled and where is it leaking?
HOMEHARDWARE65
the sled has 2800 miles on it and I couldnt tell u where it is leaking. By looking at it on the trail I couldnt see were it was leaking, but I was always down about a litre of prestone whenever the heat light would come on. And I just got this back from the dealer after puting a stud through the heat exchanger. And when the stud thing happened the motor got hot enough to lossen the bolts in the oil pan, so i'm thinking a stuck thermostat or the head gasket
Nine2Nine
HOMEHARDWARE65 said:the sled has 2800 miles on it and I couldnt tell u where it is leaking. By looking at it on the trail I couldnt see were it was leaking, but I was always down about a litre of prestone whenever the heat light would come on. And I just got this back from the dealer after puting a stud through the heat exchanger. And when the stud thing happened the motor got hot enough to lossen the bolts in the oil pan, so i'm thinking a stuck thermostat or the head gasket
Perfect storm maybe??? Keep us posted.
Apex2006
- Oct 26, 2009
- McHenry, IL
Let us know aht you find. You will need to get in there with a good flashlight after you remove the pod, plastics, and upper frame to identify if it is truly the head gasket. Hate to find that with only 2800 miles that the head gasket is leaking.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Like mentioned earlier and in another post, check the sled thoroughly before determining that it's the head gasket.
My sled with 2k miles on it had 2 missing crank case bolts and the rest were loose. It had never been hot. So I wouldn't assume that that is a indicator.
Nikolai
If you remove the two bolts on T-stat housing the cover will come off and you pull the t-stat out. Run without it and see if the problem goes away.
- 13K
