It's been cold riding in northern mi. lately. My temp. light came on the other day so obviously I checked coolant and overflow levels, everything checked out good. Lots of snow for cooling and motor has never been apart (so no air in system). So what do I look for now?? Thermostat?? Sensor?? The light will cycle on & off but it's probably the fan helping out. Just don't want to overstress or cook my motor. K&n filters & fuel programmer are the only improvements made, but they've been on for over 3 years/5000 miles without so much as a hiccup.
Tyloooor
Check the front heat exchanger and make sure it isn't covered in ice.
I had this same issue, so I installed a second tunnel heat exchanger and haven't seen the light come on since...
Dr. FeeLGooD
They do come on with plenty of warning, not really too hot, it is just giving you a heads up. Is this happening in the deep powder, or just on frozen trails? I installed a Mountaintech rear cooler as my temp light was coming on while trail riding, and it has only come on once since.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
I was out on a -25 degree C day, on a rail bed packed real hard. You would never think the light would come on but it did. There was not enough loose snow coming up for the heat exchanger I guess.
I notice when its colder than -15 C, the icing in the tunnel is bad and can severly block snow efficiently getting up to the front of the tunnel.
Was this a possible issue for you?
I would have thought the rad, with that kind of cold air to be had, would have kept the temps under control but I was wrong....
MS
MS
Dodge Ram
Sevey said:I was out on a -25 degree C day, on a rail bed packed real hard. You would never think the light would come on but it did. There was not enough loose snow coming up for the heat exchanger I guess.
MS
X2 on this. Are you riding in loose snow? I had my light come on once from Fredric once on very hard packed snow.
mcamzr
My light would come on all the time last year so I put a temp gauge on and I was running in the 200's all day. Over the summer I put the MountainTech cooler on and so far this year it hasn't go over 172. That includes a 20 mile ride around my house with me and my 2 boys on the sled and a top speed of 40 ish. The cooler is the answer IMHO, the front cooler isn't big enough and the rad can't get enough air through it.
One other thing I thought that helped was the ip vent. Now when I stop I can see the heat coming out and steaming up the gauge.
phibberz
- Feb 9, 2013
Tunnel exchanger is great...another idea..
I had issues of the same....I went overboard and did a few mods last summer...installed rear tunnel cooler, IPVent, replaced coolant to ensure proper mix, and installed duraflex scratchers and a temp gauge...
I can say that I do not have any issues now after a brutal first season...I don't ride hard and the temp this year so far has only went into the 170 range..mostly in the 150 range...
i can say the scratchers typically drop temp easily 15 degrees when I drop them on roads etc...great tool to help...easy install and I think about $75...there are cheaper setups I am sure...I am impressed with the duraflex though!
Let me know if I can be of any help - I ride an 09' Nytro RTX SE
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Have no idea what your even riding? Perhaps old coolant??
