snopro24
Brought my sled in the garage and overnight there was a small puddle of motor oil on the battery side. It doesn't look like its coming from the chaincase rather than the bottom of the pan. Any direction? Thoughts? I haven't taken it apart yet but am hoping that it's something minor...thanks in advance for any direction!
gitrdun
Check the obvious first, tank drain bolt, pan drain bolt, oil filter, make sure they are snug. Did you lay it on its side lately? Also, I would have a good look at the oil tank, there have been reports of the mount area cracking and possibly leaking from there. Enough of a problem that someone already makes an aftermarket heavy duty tank for the Nytro.
1975FA
My oil cooler o-ring leaked and made a leak that was hard to see without removing the air box.
pro116
It's a common problem for the Nytro oil tanks to crack.Someone makes an aftermarket one.I believe oft sells them.
bmazbnytro
Do a search, been covered a million times. Most common cause is oil in the air box from the engine vent tube. The airbox is open on the bottom and then the oil runs down the motor and drips on the floor. Take lid off airbox, remove filter and screen and check for oil in box. Wipe out oil, reassemble, check fluid and enjoy. If the oil is over filled the slightest bit this will happen.
snopro24
Ok thanks. Oil hasn't been changed since last year and it hasn't been tipped on its side but the sled does have a rollover valve. Thanks for the tips guys. I will be tearing into it on Monday.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
pro116 said:It's a common problem for the Nytro oil tanks to crack.Someone makes an aftermarket one.I believe oft sells them.
x2
09nytro
Could be pushing out the breather into the air box and dripping out the bottom and running down the front of the engine onto skid plate out on ground
mpbrix92
- Nov 30, 2015
- Sheboygan , Wisconsin
- 2009 Yamaha Nytro RTX, pretty much bone stock
Can overfilling the tank cause it to totally leak out or do I have bigger issues
