fast4fun
- Dec 16, 2011
I am running an MPI 180 between sea level and 1600 feet. Just installed it and it seams to be running extremely rich and idles around 1100 rpm. What is the cure for this? Has. GEMS controller but can’t get the idle up any. Thanks
sideshowBob
If it were me...
I would contact a vendor like Ulmer or Hurricane and get a PC5 with PTI, Auto Tune, and a Pod 300. You would never regret it.
I honestly don't know how I ever tuned sleds for the last 35+ years without these tools!
JM.02c
JM.02c
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
I would get in touch with MPI I'm sure they will get ya pointed in the right direction. I did here they had some problems with the gems controller, you may have to send it in to get the right tune programed back into it.
fast4fun
- Dec 16, 2011
I spoke with MPI today and they told me they didn’t really have an answer. The turbo was designed to run in high altitude and he wasn’t sure what settings to use at sea level. Said to get an afr gauge and try to set it up starting with the super charger instructions on the website. Getting a gauge tomorrow. Hopefully I can get it in range so I can ride this weekend.I would get in touch with MPI I'm sure they will get ya pointed in the right direction. I did here they had some problems with the gems controller, you may have to send it in to get the right tune programed back into it.
fast4fun
- Dec 16, 2011
I was hoping to set it up with the GEMS controller that came with it. Getting an air fuel ratio gauge tomorrow. Going to mess around and see what I can come up with. My buddy has an MCExpress on his and he had to turn the air screws half a turn each to raise the idle. No mention of air screw adjustments in the MPI instructions tho. If I can’t get it I’ll have to try a different controller. I have a PC3 but I would thinks it’s kind of outdated for what I’m trying to do.If it were me...
JM.02c
sideshowBob
If you are considering going the PC5 route,[it is obviously not cheap] I would save my money on an AFR. A PC5 with Auto Tune and Pod 300 will give you an AFR readout as well as many other info settings. Ulmer or Hurricane should be able set you up with a base map that should be real close.
If you touch your air screws make sure you record your current settings so you can always go back.
TPAY243
- Apr 14, 2013
- Northern Wis
Have you tried to adjust the gems controller if so where are you at with it right now. You definitely need an AFR gauge so you know where your at regardless. Just installed one of these kits on a friends machine we are at 1.5, 3.5, 3.5, and 3.5 on the controller. Sounds like you need to lean yours down on settings 1 & 2
fast4fun
- Dec 16, 2011
Going to try afr tonight as I have a loaner gauge. I will for sure record air screw settings if I end up adjusting them.If you are considering going the PC5 route,[it is obviously not cheap] I would save my money on an AFR. A PC5 with Auto Tune and Pod 300 will give you an AFR readout as well as many other info settings. Ulmer or Hurricane should be able set you up with a base map that should be real close.
fast4fun
- Dec 16, 2011
I have adjusted the gems but I think it still needs more. Trying the afr gauge tonight.Have you tried to adjust the gems controller if so where are you at with it right now. You definitely need an AFR gauge so you know where your at regardless. Just installed one of these kits on a friends machine we are at 1.5, 3.5, 3.5, and 3.5 on the controller. Sounds like you need to lean yours down on settings 1 & 2
Blownhard
- Mar 20, 2017
- Niagara Falls
- Nytro xtx
Sidewinder ltx-le
Bob are you Running a pcv pti with autotune if so did you install the can button?
