Nytro not returning to idle
Pdebone
Age
46
Driggs, idaho
2010 fx nytro mtx
Having some trouble with my 2010 nytro mtx. It starts and idles fine and runs strong after initial warmup. My trouble is when after riding any amount of time or distance the sled stalls out as soon as i let off the throttle and it returns to idle. I've bypassed TORS to eliminate that from possible solutions
Check the vent line for the idle control circuit hose. It should be about a 1/2 to 3/4 diameter hose going to the airbox. If it's plugged the sled won't idle.
Wouldn't that effect the initial idle as well. Like I said only happens after driving, startup everything appears to run normal. I'm also wondering if it could be a spark plug issue. Thanks for responding
i'll take a look tonight or in the morning after work. Also no codes showing up
Tightened the throttle cable a bit, seems to have done the trick for now anyways. Hose didn't appear to be clogged
