NYTRO OVERHEATING!!
Prescott, Ontario
I took my nytro north yesterday and when I got there I found that it kept over heating every 10-15 minutes. When I stopped I noticed i would be down about 1 litre of prestone and it would be all over the belly pan. Also, none of it was coming out of the overflow. I think it might be the headgasket, but I would like to hear your guys apinions before I take it somwwhere.
Check your hoses and connections before deeming it as a leaking head gasket. You should be able to determine visually where it's coming from.
Pull all panals let it run and see where it leakin may be a thermostat or something or may be a hose
If it is all over the belly pan i would say its more probable to be a leak than the headgasket, but if you kept running it hot to hot light to hot light, you might have done in the headgasket as well.
