Nytro rtx, max rev
Nitroya
Would like know specs on Nytro top rec, (redline) , 2009 model, installed clutch kit, heel clicker, helix and both springs, only reaching 8450 rpm, Should it be higher?
You should be targeting your peak Hp, which is 8,800rpm for stock engine and 8,900-9,000rpm with a header/can/K&N combo. Rev limiter kicks in around 9,200 rpm..
Puttin a stiffer spring in primary, would that work to.
your finish should be stiffer to bring your shift out up if you get a stiffer start it will only raise the engagement.
I think the limiter kicks higher then that. 9400 range.
revster said:
I think the limiter kicks higher then that. 9400 range.[/quote
Nope 9200-9250 is stock on nytro...it can be raised with a programmer.
