Nitroya
- Nov 12, 2012
Would like know specs on Nytro top rec, (redline) , 2009 model, installed clutch kit, heel clicker, helix and both springs, only reaching 8450 rpm, Should it be higher?
JP270NYTRO
your to heavy you should be 8900 to 9000...take some weight out or wrap the secondary more.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
You should be targeting your peak Hp, which is 8,800rpm for stock engine and 8,900-9,000rpm with a header/can/K&N combo. Rev limiter kicks in around 9,200 rpm..
Nitroya
- Nov 12, 2012
Puttin a stiffer spring in primary, would that work to.
JP270NYTRO
your finish should be stiffer to bring your shift out up if you get a stiffer start it will only raise the engagement.
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
BADSLED said:You should be targeting your peak Hp, which is 8,800rpm for stock engine and 8,900-9,000rpm with a header/can/K&N combo. Rev limiter kicks in around 9,200 rpm..
I think the limiter kicks higher then that. 9400 range.
JP270NYTRO
revster said:BADSLED said:You should be targeting your peak Hp, which is 8,800rpm for stock engine and 8,900-9,000rpm with a header/can/K&N combo. Rev limiter kicks in around 9,200 rpm..
I think the limiter kicks higher then that. 9400 range.[/quote
Nope 9200-9250 is stock on nytro...it can be raised with a programmer.
