rippintheyammi
- Oct 29, 2021
- 2010 Yamaha Nytro RTX SE
I've recently acquired a 2010 RTX SE and have put all my suspension settings back to standard in the manual. When i sit on the sled in the garage the rear suspension will compress and not return unlessI lift the rear. Any thoughts?
Set to soft, need more spring, maybe needs shocks rebuilt, is it greased?
ateick
- Mar 11, 2019
- '24 Rene XRS 900R
'18 SR Viper RTX (SOLD)
'20 Poo XCR 850 (SOLD)
Sleds not on dolleys is it? If it is then the suspension won't react normally. Take off the dolleys and try again.
rippintheyammi
- Oct 29, 2021
Tried off the dollies and it is still the same.
Set the spring to soft? I just set everything back to standard in the manual which is M on the spring block
It will have more set in when its on Medium or Soft, it wont return to the top of the stroke. It will have more fall out when air born.
rippintheyammi
- Oct 29, 2021
I've got it set to medium.
Maybe the grease is the issue. I'm having a hard time getting grease to take through the zerks.
That could be part of the problem.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
You don’t want it to come all the way back to the top of the stroke when you get off it. You want it to have some sit in. You want the suspension to ride with in the shock stroke, stiff enough so it doesn’t constantly bottom out but not so stiff that it tops out either. It should drop 3 to 4 inches when you sit on it and come up 1 to 2 when you get off. If it tops out when you get off it’s to stiff. If it doesn’t rebound at all when you get off it’s to soft.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
When is the last time the shocks have been serviced?
rippintheyammi
- Oct 29, 2021
I understand sag and how to set up suspension. Lots of sleds, dirt bikes etc. Not expecting it to go all the way back up but seems like it is almost bottoming and then not coming back up much at all.
Not sure when / if shocks have ever been rebuilt. I just bought the sled
Keith1962
- Mar 26, 2015
- Camillus, NY
- 2009 Nytro XTX,OFT Relocator, Excell exhaust, Curve Skis, Excell wheels, Dupont Slides. Star Suspension. Hygear Billet rear shock and spring spacer. Air Box Mod. Clutch mods, Polished tunnel. Custom GPS mount. BOP Skid Plate. RSI handwarmers.
Pull the shocks and test.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
Shocks don’t lift the sled back up the springs do. Shocks dampen and control spring motion. Either springs are weak or suspension pivot points are binding
