yamahacat69
nytro rtx stage 1 mpi 5 psi new clutch kit they sent me 50 g super tips blue silver blue primary spring 53/41 helix purple spring wraped at 0-1. my issue is it hits rev limited soon as u squat the trottle heels loaded with 2 tungstens and 2 washers middle empty tip empty,, then i added few grams in middle now the top rpm is down to 8400,, is my weights no good to me anyone care to chime in thanks
BlueApexXTX
Call Allen Ulmer.. One phone call for me and Clutching has been spot on for over 6000 miles.Ulmer Racing161 E Poplar St
Menno, SD 57045
Phone: 605-387-2833 Fax: 605-387-2883 Email: Srxspec@Gwtc.net
Menno, SD 57045
apexgturbo
- Feb 9, 2012
- terrenceville
- 2008 Nytro,2009 Nytro mtx,2006 apex drag sled
try a white Yamaha secondary spring wrapped at 6/1.or 3/3
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
I agree call Allen ulmer. good guy, and knows his clutching
It sounds more like a secondary spring wrap if at launch you hit the rev limiter then as it catches up your ok. Try 3/3 wrap and make sure you have the proper wind on the spring or it will bind on shift out slowing it to the primary shift
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
Agreed, call Allen! Sounds like you need more cam like 56/41, that will make it shift harder in the earlier part of the shift. If you are wound at 0-1 I would guess you have a pretty stout driven spring with tang's aligned? Many ways to skin a cat when it comes to clutching but I'am sure Allen could put you spot on with the first try and he won't sell you a load of crap you don't need!
m.schuey7
- Feb 4, 2014
- Colorado Springs, CO.
- 2011 Yamaha Nytro XTX
Very simple fix, call MPI and order 6 of their large steel rivits, add two to each clutch weight. I'm running same system and was also easily over revving. Pulls like gangbusters now with no over-rev, hard to read the tach at WOT but max revs appear to 9,000.
