Does anyone know if a 08 Nytro RTX rear suspension will bolt right into my 05 RX1 with NO modifications?
sgilbert
I actually have less than no idea, but swapping any totally different suspension with "no" mods is dreaming
Alatalo
- Jan 11, 2005
Depends on your own definition of "no mods"...
If "no mods" means drilling no new holes, then the answer is no. From what I remember, the mounting points of the -05 MonoShock and the -08 Dual Shock are not the same.
If you can measure the mounting points of the -08 FX Nytro and then drill and fabricate them in exactly the same position in your -05 RX-1, plus making sure that the width of the tunnel is the same, then why not...?
mytro
Alatalo said:Depends on your own definition of "no mods"...
Alatalo Sent you a PM.
