mllr25
- Feb 3, 2008
Anyone know if these skis will fit a 08 Nytro they make them for RX1 didnt know if that would be the same
dooflyinryan
Does anybody know how wide these skis are? Do they get up on the snow real good for off-trailing? Which carbide length is reverybody running, 4", 6" or 8"?
I got the same question as above, do you get the RX1 mounting bracket for an '09 XTX?
Thanks,
Ryan
Thanks,
Ryan
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Try a search, there have been some posts regarding these skis and their specs.
Daddy
- Mar 19, 2008
I have them on mu 09 SE, seem to work fine, little darting and tougher steering pressure needed to turn them, though not as bad as a set of C&A pro's I had on. Had to cut the sleeve that runs through the spindel by 1", other than that it bolted right on.
Daddy said:I have them on mu 09 SE, seem to work fine, little darting and tougher steering pressure needed to turn them, though not as bad as a set of C&A pro's I had on. Had to cut the sleeve that runs through the spindel by 1", other than that it bolted right on.
i think you got the wrong mount. they should bolt right on. so far i dont believe they have a mount for a nitro style rubber which relies on there being something behind it to work and put down pressure on the back of the ski. to use them on a nitro for now you will need to take a piece of stainless or aluminum angle iron and bolt in just behind the rubber using the two carbide mounting studs that come up through the ski right there.
if that ski is darting it must have very little rear pressure at all on the rear of the carbides. they need to be set at 0 or a little rear bias.
Daddy
- Mar 19, 2008
Like I said,they bolted right up, ski saddle was like an 1/4 " to narrow for the sleeve that came with it. The angle iron you are talking about is on the ski saddle. They work good.
picture please, I havent seen mounts yet for the nitro
- 25K
