Hey guys, I think you want to be directing your questions to Seth Thorson ... Aaron is the photographer.
yam177
- Aug 14, 2008
- Shoreview MN
- www.jbeurotech.com
DGZRT said:Hi Aaron, You guys looked very busy tring to get thinks set up so I refrained from coming over and bugging you guys. From the sucess you guys are having , you must be reporting back to the big guys on how this front suspension works ? When can us little guy's see something new on the Nytro?
Is that a new color blue or just something the racers came up with? It looked great.
Good luck the rest of the Year and kick some A....S !
Sorry Guys busy working on sleds.
Arron is the Photograher.
The racers you see in the Midwest are Nathan Titus Ross Erdman. Jake Jorgenson, Ben Lindbom and Seth Thorson(me)
Yamaha's engineers and people re involved in the race program s this is a factory effort. The color on the sleds was Yamaha's choice
As for handling yes that front end really shines and helps in cornering and stability of the sled. The sled is more predictable when it get harry and reacts the same almost every time. From racing both versions it is a big improvement.
As for us seeming busy when at the track we are constantly changing and testing things, however there is generally some time or a few quick min. to chat SO feel free to come up and introduce yourself and if we have a minute we would be glad to talk.
Thanks for supporting us
Seth Thorson #177
yam177
- Aug 14, 2008
- Shoreview MN
loudelectronics
- Dec 1, 2007
- Souris, Manitoba
- presdwr.spaces.live.com
Any weight savings? Spindle moved forward like the skinz kit? Looks closer to an AC styl suspension.
yam177
- Aug 14, 2008
- Shoreview MN
loudelectronics said:Any weight savings? Spindle moved forward like the skinz kit? Looks closer to an AC styl suspension.
Yes the whole front is moved forward. It is a complete new sub frame as well. It is very different than the skins kit.
It is lighter than stock
mattyg1405
can anyone tell me the part number for the exact windshield on seth's sled?
its not listed online and i want that exact windshield and the side deflectors
thanks in advance
thanks in advance
shockwave
- Feb 25, 2010
- St Paul d'abbotsford Québec
- 09 Phazer RTX
I see that you are running without sway bar on this front. Do you get much inside ski lift with that set up? How many PSI are you running in your Float X?yam177 said:loudelectronics said:Any weight savings? Spindle moved forward like the skinz kit? Looks closer to an AC styl suspension.
I saw your 2 vids on You Tube and enjoyed them, have a great racing season!
yam177
- Aug 14, 2008
- Shoreview MN
shockwave said:I see that you are running without sway bar on this front. Do you get much inside ski lift with that set up? How many PSI are you running in your Float X?yam177 said:loudelectronics said:Any weight savings? Spindle moved forward like the skinz kit? Looks closer to an AC styl suspension.
I saw your 2 vids on You Tube and enjoyed them, have a great racing season!![]()
We have been running the 2012 RTX valving in the shocks. In the float x's we run 110 PSI. There ARE sway bars on every sled
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
You won't see a new front end on the Nytros this year, maybe 2014, but not the 2013 models.
shockwave
- Feb 25, 2010
- 09 Phazer RTX
yam177 said:shockwave said:I see that you are running without sway bar on this front. Do you get much inside ski lift with that set up? How many PSI are you running in your Float X?yam177 said:loudelectronics said:Any weight savings? Spindle moved forward like the skinz kit? Looks closer to an AC styl suspension.
I had to pay a close look at your pictures but I just notice the sway bar. I really like the fact they seam to be located above the lower a-arm instead of bellow. Better ground clearance. I hope that Yamaha will eventually come up with something like your ride for us. Thanks for the info on your shock set-up.
mattyg1405
thats alot of air pressure but i guess it IS a totally different fron end.
LeeKo
New front end
I would like to hear some feedback/ comparisons to this front end verse stock. I love my nytro but have spent significant money on on shocks and a- arms to get it to work properly. I have been yami brand loyal since 1981 but enough is enough. Just cause they have the best motor they can slack on everything else? Yamaha get your head out of your a__ why aren't you updating the 2013? Sorry to take the op to rant but I would like to hear about your experience with the new geometry. Thanks.
Leeko
shockwave
- Feb 25, 2010
- 09 Phazer RTX
mattyg1405 said:thats alot of air pressure but i guess it IS a totally different fron end.
I went from 65lbs to a 100lb, ease off the compression damping and like it much better. I must also say that I am running more preload on the front skids shock.
mjaremko
Suspended
I'm running 130psi in my Float2's.
mj
mj
yam177
- Aug 14, 2008
- Shoreview MN
Its all personal preference but yes this front end react completely different than the stock one
