Nytro Nasty
- Oct 17, 2014
- 2008 Yamaha FX Nytro 136, mountain fit vent kit, oft steering relocate, mountaintech skid plate, simmons flexi skiis with 6 dual runners, skinz front bumper, DDM Tuning HID lights, 55 watt ballasts with 4300k bulbs.
All done in one season.
That's is so far but much more on plate for this year!
Will I notice anything different after being installed?
ChiefMn
- Aug 25, 2013
You will hopefully notice less iceing in your tunnel.
Nytro Nasty
- Oct 17, 2014
Oh ok Ya that sucks.
Tommyboy
- Oct 24, 2014
- Keswick, ON
- 2009 Nytro
Thanks,The Copper donuts will last 2-3 times longer then stock. Should get 10000 or more miles out of the copper. The copper gives a better seal when cold over the stock.
Nytro Nasty
- Oct 17, 2014
Who has the best price on these as I would like to purchase a set soon. Got trail tank on way and would like to do it all at the same time if possible. Doing cr10ek plugs at same time also. Thanks
Tommyboy
- Oct 24, 2014
- Keswick, ON
- 2009 Nytro
Thanks, just ordered trail tank and 128" star suspension kit and will be sending centre and rear shock to Star for revalving , how did your tank retro go and what are your thoughts about the suspension upgrade. Cheers !I put on copper donuts from sled toyz this fall. Fit was very good.
pay2play
My tt went in smooth as butter. To get panels to fit, I moved it more forward, the rear bolt holes are slotted giving room to adjust. This is really only needed for panel fitment, at least in my opinion. I needed to purchase on additional dzus fastener that was longer than the stock one, Seth gives you two with the tank that are plenty long. I have an XTX and really liked the star kit. He did my shock too. Robert was great to work with and was willing to help me set it up and make adjustments after I had it installed. Enjoy!
Nytro Nasty
- Oct 17, 2014
Mine should be in the mail any day. Been waiting for black to come into stock.
Budyzer
- Oct 5, 2014
- 2009 Yamaha Nytro XTX
Just picked up a 09 Nytro xtx so this machine is new to me. I would like to remove the tunnel protectors to avoid some of the icing issues that I have been reading about. My question is, do I have to remove the heat exchanger protectors and the tunnels protectors? Or can I leave the heat exchanger protectors on? I would rather not touch the heat exchanger if I don't have to. Thanks. Great site!!!
hittoomanytrees
If all you want to do is reduce icing, you can leave the heat exchanger protectors in.
pay2play
X2
Budyzer
- Oct 5, 2014
Thanks. Let it snow!!!
TLM
- Jul 19, 2014
- Hortonville, WI
- 2012 Nytro xtx, oft relocate, oilite bushings, comfort clutch, tunnel block, tailight relocate, cr10EK plugs, copper donuts, tuner skis, Grizz Tracks gusset kit. Excell x wheels. Mo-Flow console vent and curved vents.
I was reading another thread about the 1.75" back country track. I know you have to remove the tunnel protectors for this track but haw about the ones on the heat exchanger?
hittoomanytrees
If you are installing the backcountry track you need to remove the heat exchanger protectors.
Off Trail Mike
Gone Riding!
- Dec 26, 2009
- Bathurst, NB, Canada
- MTX
Nasty:
As everybody said, the copper donuts are the way to go.
There is a small tab on the exhaust clamps (that hold the donuts) which prevents the stock fiber donuts from being squeezed too much. I would grind off a millimeter or so to ensure you are getting good clamping on the copper donuts. I've done this mod on my old 09 xtx (with copper) and my 11 mtx (with stock) and knock on wood, haven't had a problem with either sled since
Regardless of what you use, keep an eye on the donuts/heat shield at least every 2nd year. With the trail tank, there is no room between the upper heat shield and the tank. On the stock tank, they left an inch or so air gap, but to gain volume, the eliminated that space on the trail tank. You don't want 1000 deg F exhaust gas blasting toward your trail (fuel) tank!
OTM
OTM
