Nytro turns over as soon as key is on
emr333
Saskatchewan, Canada
I just had my Nytro completely apart , engine out for a new head gasket. The first time I turned the key on it started turning over. I turned it off immediately then back on and it didn't turn over. When started the starter would kick out and it ran fine. I went to start the other day after it was all back together and now I can't get it to stop instantly cranking. Any ideas where to start?
faulty ignition switch would be my best guess, although I would trace the start circuit wires just to confirm you haven't pinched a wire and its grounding the relay or something causing it to crank over :-)
Check the key connection. They can corrode. Just keep following everything back from there. Could be the starter solenoid but it seems odd there was no indication of it leading up to this.
