yamahahaha
anyone race against 800r's???
rage man
yea actually 2 wernt thoes supposed to be light and have all this power well i murder them out the hole and 6-7 hundred feet theses nytros work good then they went buy but wern't that far behind in 1000+ feet down the lake that is plowed
Turk
Tech Advisor
Do it every weekend. 09 is an animal & not even close. 08 is close if you race a weak one.
Arnold08
I would Listen to Turk He seems to give good information this IM not so sure if the other guyz info is legit i raced an 08 we maybe were even out of the whole but not even close after that he pulls not real hard buthe just steadily drives away hahaTurk said:Do it every weekend. 09 is an animal & not even close. 08 is close if you race a weak one.
2008 Nytro RTX
Is this stock vs stock?Turk said:Do it every weekend. 09 is an animal & not even close. 08 is close if you race a weak one.
Turk
Tech Advisor
Stock-ish
OK, What do you consider STOCK-ISH?Turk said:Stock-ish
loudelectronics
Clutch work.
Turk with this new snow we should go for a ride this weekend in the TM's.
I let some guys take my sled for a ride that use rev 800's and 700 SB. They thought it was slow and had no power??? Then I raced one of them. It must have been the loose snow they were driving it on and the track not hooking up, cause when I raced them I was out in the lead till we ran out of room.
280chopper
ride with all 800r 2 08's one 09 they all were pulling me now have excell full system and 900 miles beating them out of the hole and pulling them top end now both 08's are clutched one piped 09 is stock we all have 96 studs, this sled definately gets faster with miles and pipe made big differance, think a good clutch kit would help as well just not sure which one to buy, i also have 08 800r x and 600x etec so not biased
unpride
I ride with 3 of them an the 09 XP 800 is quick. I can take them out of the hole for a bit then they cruise by but dont really go that much faster top end. It seems their mid range hit is the ticket. Still id rather be on my Yammy
Southern Renegade
- Jan 27, 2009
- Rock Island Arsenal, Rock Island IL
- 2009 Polaris RMK Shift 144
well I had a 08 800R and traded it for a nytro XTX. I will tell you the 800R will eat it up. I consider the XTX more of a 700. Out of the hole I was close or slightly ahead but after that it was all 800R. I ran closer with the 05 800HO summit on the same race. summit is geared low so hard pull up front with my XTX but I took him after that. I had taller gears. I like the smoother engine of the XTX. A lot easier on me, 800R has a hard throttle pull.
2008 Nytro RTX
Consider it a 700 out of the hole? You mean a 700 as in an F7 right? I can pull an F7 for about 2-3 sleds until top speed then he SLOWLY creeps by me. I have seen Nytros take XPS and XPS take Nytros.Southern Renegade said:well I had a 08 800R and traded it for a nytro XTX. I will tell you the 800R will eat it up. I consider the XTX more of a 700. Out of the hole I was close or slightly ahead but after that it was all 800R. I ran closer with the 05 800HO summit on the same race. summit is geared low so hard pull up front with my XTX but I took him after that. I had taller gears. I like the smoother engine of the XTX. A lot easier on me, 800R has a hard throttle pull.
Southern Renegade
- Jan 27, 2009
it felt like a 700 compared to my 800R. my brother has a 09 and I ran him and a 800HO. I didnt last long against the 800R. I got sick of leaking antifreeze and carbs that dealership couldnt dial in so I went with the XTX. I like the suspension and bottom end torque but the 800R is a beast just my .022008 Nytro RTX said:Consider it a 700 out of the hole? You mean a 700 as in an F7 right? I can pull an F7 for about 2-3 sleds until top speed then he SLOWLY creeps by me. I have seen Nytros take XPS and XPS take Nytros.Southern Renegade said:well I had a 08 800R and traded it for a nytro XTX. I will tell you the 800R will eat it up. I consider the XTX more of a 700. Out of the hole I was close or slightly ahead but after that it was all 800R. I ran closer with the 05 800HO summit on the same race. summit is geared low so hard pull up front with my XTX but I took him after that. I had taller gears. I like the smoother engine of the XTX. A lot easier on me, 800R has a hard throttle pull.
2008 Nytro RTX
I understand,You were stating your opinion and I was stating mine.Southern Renegade said:it felt like a 700 compared to my 800R. my brother has a 09 and I ran him and a 800HO. I didnt last long against the 800R. I got sick of leaking antifreeze and carbs that dealership couldnt dial in so I went with the XTX. I like the suspension and bottom end torque but the 800R is a beast just my .022008 Nytro RTX said:Consider it a 700 out of the hole? You mean a 700 as in an F7 right? I can pull an F7 for about 2-3 sleds until top speed then he SLOWLY creeps by me. I have seen Nytros take XPS and XPS take Nytros.Southern Renegade said:well I had a 08 800R and traded it for a nytro XTX. I will tell you the 800R will eat it up. I consider the XTX more of a 700. Out of the hole I was close or slightly ahead but after that it was all 800R. I ran closer with the 05 800HO summit on the same race. summit is geared low so hard pull up front with my XTX but I took him after that. I had taller gears. I like the smoother engine of the XTX. A lot easier on me, 800R has a hard throttle pull.
Southern Renegade
- Jan 27, 2009
I agree, like they said in snowgoer magazine. It is really the driver and holeshot. I seen lesser sleds take bigger CC ones due to inexperience. What was hurting my sled is XTX running 1.25 ripsaw. If I was running 1.75 might have been different. bottom line it is all fun to pull the throttle!
