sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
No you don't need the auto tune to run the pc5.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
A auto tune is not mandatory. I believe if you're running full exhaust you should have either a airbox mod or K&N filter set-up along with a PCIII or PCV. I know some guys don't bother with an intake mod because they feel it's too noisy but run the other mods such as PC and exhaust with a different maprage man said:so i need a pc5 with ulmer map an air box mod an i dont need to get the auto tuner
I have a PCIII for sale that requires a flash (firmware) and I could supply a Map. I would suggest you buy a K&N kit + PCV from Ulmer and he'll pre map it for you.
nitris223
- Nov 18, 2012
- Yorkton Saskatchewan
- Yamaha Nytro MTX
I never really noticed the noise from the air box mod. Maybe I will try and listen for it this year. Was to busy last year listening to the sound of the pipe. Are the K&N's louder then the air box vents I wonder.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
From the guys I have talked to about K&N's that trail ride wear ear plugs because of the noise. Do the air box mod; same gain, less noise, less headache
rage man
cool what air box mod instead of k&n ?
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Mod from hurricane, holes in the lid and bottom of the box. It was specifically produced to gain max hp with the hindle exhaust in a kit from hurricane. Tuned with the pc5
