johnelway
ok here the situation. can somebody help me.
fx nytro xtx 2010
the problem was present when the sled was stock. nothing related with the mods
i run the sled over 8000km like that afterr i bought it used.
the problem is that as soon as i touch the throttle, the engine stop.
after that, i need to apply little bit of gaz to start it and get moving.
if i just turn the keys, the engine don't start.
also, when slowing down and stop, as soon as the clutch disengage, engine don't want to idle so it stop.
when i made it idle, the rpm is getting between 8-900 an 1000-1200.
seems too low for me.
and when idling, touching the throttle made it stop.
anybody can help me?
sorry for the text, i'm a french guys and it's hard to explained
thanks
fx nytro xtx 2010
thanks
Change plugs and if that dont work, unplug PCV and see if it still does it.
johnelway
i already change the plug for cr10ek last year and no change.
not pc5 related.
like i said, the problem was present when stock so not related to mods.
i tried the plugs, pc5 and throttle cable adjustment. nothing related to this.
it is possible that the isc does not work correctly? any way to check except diag mode?
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Run diagnostic mode. Bon Chance
johnelway
or and what i'am supposed to see?Run diagnostic mode. Bon Chance
