kelly mac
- Jan 25, 2020
- moncton nb
- 2009 nytro rtx
Help
Have an 09 Nytro. Will start and idle.
As soon as you touch the throttle it stalls.
Codes coming up are 13. 15. And 25
Should I replace the throttle position sensor #25 1st?
Thank you
Thank you
I doubt it's the sensor given you have three codes.
Could be the circuit connector blocks in the harness, it's fairly common that those give trouble.
Also check for broken wire(s) near the intake air pressure sensor.
kelly mac
- Jan 25, 2020
- moncton nb
- 2009 nytro rtx
Thank you I will check tonightI doubt it's the sensor given you have three codes.
Throttle cable too tight?
- 16K
- 7K
