Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
Does anyone know if you can get a Yamaha nytro xtx tunnel block off plate for the stock exhaust in Canada?
sloan188
- Nov 28, 2012
- Vaudreuil, QC
- 2005 Polaris Fusion 900
2009 Nytro XTX
2010 Ski Doo GSX LE 1200
You can for about $20 if you make your own.
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
look under my user name and you will find the info you need to make your own. They work just as well as any aftermarket supplier and cost about $20-$30 total.
Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
I would just make one. Find a piece of aluminum sheet and trim it to fit where you need it. Thats what I did and cost me about $15.
Lman69
Guest
- Nov 5, 2013
built one for under $20 and riveted on.
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
Does it go under the tunnel or on top?built one for under $20 and riveted on.
Mills
- Dec 4, 2007
Under between the tunnel protectors
Lman69
Guest
- Nov 5, 2013
striker606
- Feb 11, 2014
- Maplewood MN
- 2009 yamaha nytro xtx
I'm planning on building my own soon also and want it on top, did you leave the lip in to top of the tunnel or did you cut it off before you put the block off on? thanksI did on top.
msgt van
- Mar 21, 2014
- Kasota, MN
- 2008 Apex LTX
I left the lip on. I didn't know how much rigidity of the tunnel you'd loose by removing that ridge. I'm sure someone will chime in with some specific info.
striker606
- Feb 11, 2014
- Maplewood MN
ok sounds good. so was there a gap or was the rivits enough to suck it down all the way around?
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Installing a block off plate on top off the tunnel does little to reduce icing. A plate attached to the tunnel protectors works better because it stays cooler and blocks snow from hitting the hotter surfaces. I actually run both.
striker606
- Feb 11, 2014
- Maplewood MN
I have my tunnel protectors removed due to running a 2" track on my xtx. I didn't have any problems last year but I just installed a mbrp pipe and it looks like there is a lot of room on the sides of it since its a small pipe so I was just thinking maybe a block off will help from getting snow and ice packed up in the seat support
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
When you install in under the tunnel, do the tunnel protectors do anything to hold the plate up? Cause I plan on getting rid of those useless protectors. They don't do anything except add more weight from ice getting stuck from themInstalling a block off plate on top off the tunnel does little to reduce icing. A plate attached to the tunnel protectors works better because it stays cooler and blocks snow from hitting the hotter surfaces. I actually run both.
Lman69
Guest
- Nov 5, 2013
Disagree, had no icing issues last year.Installing a block off plate on top off the tunnel does little to reduce icing. A plate attached to the tunnel protectors works better because it stays cooler and blocks snow from hitting the hotter surfaces. I actually run both.
