SnoBird888
- Sep 4, 2013
- Neenah, WI
- 09 Nytro xtx
So i have my skid out doing some bearings and looking things over after i got my tunnel powder coated. I noticed that the small arm were the bottom of the rear shock and pull rods connect is rotating down and making contact with the shock body? I was going to put it in tonight to see if it did this while on the sled but decided to call it a night. Is this something I need to look into or will the pivot arm rotate up when its installed on the sled? Figured id keep the skid out an extra day or so incase i need to change something on it or I am missing something obvious.
Thanks for the help!
R00STER
- Mar 3, 2013
- Timmins, Ontario
- 2013 Nytro xtx 1.75
Do you have the rear springs on? If not the suspension will do that.
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
X2
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
There is nothing wrong with your skid. THe rear arm needs to be fixed in its correct location for that linkage to work.
SnoBird888
- Sep 4, 2013
- Neenah, WI
- 09 Nytro xtx
rear spring are loaded. i kind of figured the rear arms need to be in fixed position. Was worried about nothing i guess! Thanks everyone! On a positive note the tunnel removal powdercoating, and reinstall was super easy!
stricklandj
- Feb 21, 2010
- Nova Scotia, Canada
- 2013 Yamaha Nytro XYX 1.75
Do you have a step by step on the tunnel removal!!!!
SnoBird888
- Sep 4, 2013
- Neenah, WI
- 09 Nytro xtx
I tore it off so fast i didnt grab pictures. however when it comes down to it the removal and reinstall was 10x easier than expected. if i didnt have the gas tank and plastics back on my sled id take pictures.. maybe if it comes back off i will.
