apextenn
- Nov 29, 2009
Hey just wondering if any other of you have had a problem with the fan in the rad staying on i have to diconnect my battery when i shut my machine off or it will drain the battery as the fan runs when the key is off. I am guess it is a switch or something but i was wondering where it is located. It is a 09 nytro with a powderlites stage 2 kit would the kit have something to do with it as well?? Any input would be appreciated getting old diconnecting the battery all the time.
Ironmanstl
Had same problem..
it is your fan relay located in the bank of 4 relays
I always carry a spare now.
If you have an earlier powderlites kit where the relays are relocated at the bottom front of the sled this is the problem.
Dave now relocates the relay strip to the top of the charge tube, above the clutch shroud.
Since he welded some bungs on it for me and i covered the relays with a piece of rubber they stay dry and no more problems.
