Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
I have the ECU master as well. What 02 sensor did you end up getting?The issue I had was ECU Master. One just quite the other made strange the whole time it was in use. Sometime seemed right other than taking five minutes of driving it at 6000 rpm to come of of 14.8
If you bought an ecu master last ,January , making strange I’d say change the module, it should be a warranty item
It took the fun out of quite a few rides as your staring at the gauge questioning if it’s working or not
I never did get an answer to the question if it read 14.8 in a false reading for extended periods of time , is it compensating by adding more fuel?
For what it’s worth right now if I was tuning another sled I would have a hard time to spend the extra money. That might change but I doubt it
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Sorry I thought it was an aem that I had the issue with but reading this thread I have the ecu masterI have the ECU master as well. What 02 sensor did you end up getting?
Not sure what o2 sensor came with it
What ever hurricane supplies. The replacement was on warranty or goodwill from hurricane
Sorry for the confusion
Hammer Down
- Oct 7, 2016
- Loudon, NH
- Sidewinder STX-DX 2017
Apex XTX 2012
A friends SW went through two ECU faster modules that failed before getting an AEM module that has worked fine for all of last and this season now.
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
I think I will get an AEM module in that case. Mine is an ECUMASTERA friends SW went through two ECU faster modules that failed before getting an AEM module that has worked fine for all of last and this season now.
hpmaniac
- Feb 21, 2025
- Washington
- 2025 mtx sidewinder
2024 9r turbo
2025 summit xpert 165 turbo r
Dealing with this right now, On my second ecu master unit, have seen the closed loop work one time in the shop for about 10 seconds on a fully warmed up machine running for 5 minutes on track stand. From my research the ecu master stuff is NOTHING but issues. Should be called ECU DISASTER.
Try this one. Haven't had any trouble with them at all. https://www.summitracing.com/parts/AVM-30-0310
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Have one on my sled so far so good. Haven’t had any problemsDealing with this right now, On my second ecu master unit, have seen the closed loop work one time in the shop for about 10 seconds on a fully warmed up machine running for 5 minutes on track stand. From my research the ecu master stuff is NOTHING but issues. Should be called ECU DISASTER.
Turboflash
- Mar 18, 2019
- Southern MN
Looks like O2 sensor is same as what most use - Bosch LSU 4.9.
Be aware of things that shorten sensor life. For example, starting cold sled, running it for only a couple minutes, then shutting it off. Doing this repeatedly. Storing sled in humid environment (condensation on sensor). ANY gas or additives/treatments that contain lead (ie race gas, some octane boosters, etc).
You can buy genuine oem 17025 Bosch sensor on eBay for about $23. How good can they be? Lol
Av gas [100 LL] is great for blending with premium fuel to increase the octane a few points but I have found that most sleds don't run well on pure AV gas and I avoid it on anything but old school two strokes as 100 LL AV gas is also VERY high lead content and even small amounts blended in fuel destroys O2 sensors very quickly.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
If you buy a sensor from a outside source is it plug and play or do you have to change the plug to fit the aem or ecu master module?Looks like O2 sensor is same as what most use - Bosch LSU 4.9.
I purchased a few O2 sensors from Rockauto...Bosch 17025 and they are plug and play with my AEM module.If you buy a sensor from a outside source is it plug and play or do you have to change the plug to fit the aem or ecu master module?
Davidonmars
- Feb 14, 2019
- Toronto
- Turbo
ive had the best luck with bosch 17212
I believe the 17025 and 17212 use the same 4.9 sensor, are five wire, but the wiring harness is shorter on the 17212 and the 17212 was designed for diesels with higher egts so maybe its more robust?ive had the best luck with bosch 17212
My Ram 3500 HO Cummins uses the 17212 sensors.
Davidonmars
- Feb 14, 2019
- Toronto
- Turbo
the 212 is about 2” shorter, I’ve been running the 212 in my cars for a couple years and they haven’t failed yet unlike the 17025. Same plug and everything, person that put me onto the 212 figures because it was made for a diesel it’s likely more robust and seems to be the case.I believe the 17025 and 17212 use the same 4.9 sensor, are five wire, but the wiring harness is shorter on the 17212 and the 17212 was designed for diesels with higher egts so maybe its more robust?
