exhorseman
- Feb 26, 2012
o6 apex gt starts good when cold after 24 hours, stop for a chat on trail starts perfect,leave it sit for an hour spins over wont start,leave it for 2 hours starts up with the aid of me applying throttle. its driving me nuts... stator was replaced last year any thoughts..sled has 21000kms all lady driven miles..Bill
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
have you ever replace the plugs? just a thought.
black knight
can you here the fuel pump cycle and spit the excess back into the tank
Is it shooting any codes?
Jona$
Master
- Sep 27, 2010
- Northern
- Sweden
- Tapex/sks 800 -16
leaking injectors, bad ecu reading?
exhorseman
- Feb 26, 2012
I had it to the dealers and they could not duplicate the problem ,did it again today after leaving it sit for an hour but I got it going by applying throttle they checked injectors with an ecu reading they where all in normal range,no I haven't replaced plugs but going to try replacing all 4 relays at right foot and replace plugs this week they have 15thousand k on them. I took all relays apart including starter relay by battery sprayed them with electrical contact cleaner blew them dry and applied dielectric grease internally and externally on all 5.this is really maddening.
small-bore
- Feb 27, 2013
exhorseman said:I had it to the dealers and they could not duplicate the problem ,did it again today after leaving it sit for an hour but I got it going by applying throttle they checked injectors with an ecu reading they where all in normal range,no I haven't replaced plugs but going to try replacing all 4 relays at right foot and replace plugs this week they have 15thousand k on them. I took all relays apart including starter relay by battery sprayed them with electrical contact cleaner blew them dry and applied dielectric grease internally and externally on all 5.this is really maddening.
Did you get it fixed. Mine done that once already. I've only owned mine for a week and a half.
scott32
- Jan 12, 2009
- huron county, ontario
- 07 Apex RTX se, 09 Nytro XTX
If blipping the throttle allows it to start, it very well could be tors.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I would change plugs and i would be concerned with valve adjustment as a possibility a little early but would cause cold start issues.
