Ohlin shock question
yammie3687
Is the ohlin rear shock for a 05 rs vector that is available thru yamaha adjustable? Can you adjust the compression on it?
I have the Ohlin and it does have a 20 step clicker for compression dampening. It's an awesome shock and will solve all your excessive reounding problems on the 05 Vector. I will admit, however, that the cliker knob is in a very inconvenient location. Last year a few of us TY members were discussing different knob solutions, but in the end, you just have to find a way to manuever your finger tips onto the know and still have enough room to turn it.
See the attached picture. When I origignally installed this shock, my thoughts were, "WTF? I must've installed the shock wrong!" Nothing's perfect, I guess.
Good luck,
Greg
Yes, the Ohlins is a huge improvement over stock, and yes, the adjuster is extremely awkward to adjust on the trail side. Very hard to get at.
yammie3687 said:
Thanks for the info, i ordered the shock today.
Hey Yammie, didn't you just change out that shock with a modified HPG shock? Did that not work out for you?
