bobber
Looking for a place to purchase the adjusting nuts for a rear Ohlins shock on a 2009 Apex LTX GT. Sent off an e-mail to Ohlins afew weeks ago but no response. Slightly damaged mine while trying to adjust the spring and figured put new ones on over the summer.
Snowmobileaddict
dubla92
Contact Steen Hansen Racing 1-800-661-9468. They are the Canadian Ohlins distributor. They will likely have them in stock. They are located in Edmonton.
bobber
Thanks!!! Called Steen Hansen and they provided a part number(96-531-01) for my dealer to call in with. Tech recommended going with the aluminum nut as the issue I described is common with the nylon nut. And yes they have lots.dubla92 said:Contact Steen Hansen Racing 1-800-661-9468. They are the Canadian Ohlins distributor. They will likely have them in stock. They are located in Edmonton.
