gouldsjett1
Took the skid out of my 06 apex gt, when unplugging the ohlins shock I discovered the previous owner must have broke the harness side white connector off. Now I have a black and a white wire on the sled harness side and I'm not sure which one goes to to correct pin on the ohlins shock. I have a new(used) connector to fix that problem, just need to know the right wire orientation.
Have you checked: https://ty4stroke.com/threads/apex-attak-frequently-asked-questions.42869/
Its was in there: https://www.ohlins.com/app/uploads/world/documents/2006/01/MI_YA659.pdf
gouldsjett1
Thanks for the reply. I did read that link but it mostly shows the wire routing, I'm trying to make sure I dont short out anything if I reconnect the subharness wires to the wrong pins in the shock harness. The sled side subharness doesn't have the half of the white housing that plugs into the shock side white housing, I just have 2 dangling wires . One black and one white. I hope I'm describing this ok, it sounds funny as I read it back to myself.
Message @cannondale27 , he rebuild them and I would think he knows what does what.
gouldsjett1
Will do, thanks
