Irv said:
kinger said:
Its fine. After studying the repeated oil studies available from even cheapo oil as a engineer I am almost convinced you never need to change the oil EVER. The engines are so clean and the oil is so good its just not needed like it use to be.
Just validate you dont have a leak or coolant in the oil or anything catastrophic like that and your fine. I changed my oil filter once and wont touch it again. Snow has to be the very best environment for oil in 4 strokes. Zero dust, etc.
I'm going to every other year on my oil changes as long as the dipstick smell and flashlight test show it looks good. That is on my supercharged trail sled that is a lot harder on engines then stock.
Does oil not accumulate acids eventually, especially if it is not changed at least annually?
Yes but it takes sooooo long before the oil goes bad. Oil studies of different oils showed at 80,000 miles the levels of accumulation were still way below the reccomended change level.
Its easy to say "it feels good" and its cheap but its just a pure waste if you ask me. I used to change my oil every 3000 miles on my vehicals. Now I go about 12,000-20,000 miles between changes on my cars, saves me a TON of money especially since the truck is no less then $60 by the time I get out of there and I put on 30,000 miles a year on. I think there is something to be said for the sleds though that sit for long periods of time vs one that is used daily. That is why I will go every two years. Even that is probably a waste. I will send off the next 2 year oil sample to be analyzed and see what they say. If it comes back that the oil is barely contaminated and has 90% life left I may just never change the oil when I average 1000-2000 miles a year.
This isn't something easy for me to do I want the best for the machine and my vehicals but the data is very overwhelming and starting to sway me.
