Spec sheet says 4.1 qts. Doing it tonight. Will let you know.
09nytro
I put 4 in when I changed my oil
Studroes144
- Oct 30, 2013
May be a crazy question but where do I refill my chaincase with oil? Just pulled exhaust off..engine oil seems straight forward but I don't see the fill cap for chaincase
DeerHuntr
Think you have to remove the reverse actuator
Studroes144
- Oct 30, 2013
Got it thanks!
Robinmaine
- Apr 26, 2015
- Sabattus
- 18 SR Viper LTX
Ok what's the other bolt for next to the drain plug
Sent from my SCH-R970 using Tapatalk
I never took it out but looks like it just hold oil pan on?
Robinmaine
- Apr 26, 2015
- Sabattus
- 18 SR Viper LTX
Well by mistake I put the Allen wrench on it and it came loose real easy. Was thinking puting at least blue locktite on it.I never took it out but looks like it just hold oil pan on?
Yes I bet many have done that. Crazy they have a Allen screw for drain. Maybe take a paint pen and put mark by actual drain as a reminder. Do you have the torque spec?
Robinmaine
- Apr 26, 2015
- Sabattus
- 18 SR Viper LTX
I think I have it in the manualYes I bet many have done that. Crazy they have a Allen screw for drain. Maybe take a paint pen and put mark by actual drain as a reminder. Do you have the torque spec?
Robinmaine
- Apr 26, 2015
- Sabattus
- 18 SR Viper LTX
I don't have it on the lift. I did it by feel. OopsOnly 1 has brass washer
I believe it's 7.2 ft lbs. for both screws. Sorry I thought we had a torque spec thread in FAQ. Going to need to get that done!
Robinmaine
- Apr 26, 2015
- Sabattus
- 18 SR Viper LTX
It might be there but thanks for saving me a trip to the houseI believe it's 7.2 ft lbs. for both screws. Sorry I thought we had a torque spec thread in FAQ. Going to need to get that done!
Robinmaine
- Apr 26, 2015
- Sabattus
- 18 SR Viper LTX
Oil filter 12ft lb torque drain screw next to filter 7.2ft lb oil tank bolt 12 ft lb. How do you torque and oil filter with an o ring. Coating it with oil changes friction wth. The filter the dealer was so tight I crushed it trying to remove it. All the tips on here worked great. Thanks for all the info you guys posted.
Put the filter on by hand. Just turn it as tight as you can with your hand. Make sure the old o-ring isnt stuck on engine and yes lube the new one. Never had a issue. I do torque the drainbolts though.
