Oil change questions
Ok what's the other bolt for next to the drain plug
Sent from my SCH-R970 using Tapatalk
I never took it out but looks like it just hold oil pan on?
Well by mistake I put the Allen wrench on it and it came loose real easy. Was thinking puting at least blue locktite on it.
Yes I bet many have done that. Crazy they have a Allen screw for drain. Maybe take a paint pen and put mark by actual drain as a reminder. Do you have the torque spec?
I think I have it in the manual
I believe it's 7.2 ft lbs. for both screws. Sorry I thought we had a torque spec thread in FAQ. Going to need to get that done!
It might be there but thanks for saving me a trip to the house
Oil filter 12ft lb torque drain screw next to filter 7.2ft lb oil tank bolt 12 ft lb. How do you torque and oil filter with an o ring. Coating it with oil changes friction wth. The filter the dealer was so tight I crushed it trying to remove it. All the tips on here worked great. Thanks for all the info you guys posted.
Put the filter on by hand. Just turn it as tight as you can with your hand. Make sure the old o-ring isnt stuck on engine and yes lube the new one. Never had a issue. I do torque the drainbolts though.
