How involoved is it to change the oil in a Nytro?
shadow44
It's in the FAQ section at the top..no pics
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Also, in the same FAQ, you can download the service manual that will explain it fully too, as well as any other maintenance item.
Does a 2010 Nytro use the same manual?
Zakre
its almost 99 percent the same
cemjr
Oil change is a piece of cake. Instructions in the owners manual is all you need. Don't forget to drain the block. Make sure not to leave the old filter O-ring behind
nxtx
- Dec 23, 2009
Just finished mine on a 2010 xtx took about 1 1/2 hours. Not a big job at all.
schoe
Takes a little while, but no big deal
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
No problem at all compared to my Apex! The only challenge is removing the bottom left and right panels to access the motor drain plug and the oil filter. The drain plug is a hex screw with a washer. Careful not to damage the plastic inserts that hold the panels in place. Once you have done that, piece of cake! Remember to remove the drain plug to drain the oil tank on the right side as well. Takes about an hour in total including the wait time to allow full drain. Fill the oil tank level to the "H" on the dipstick without screwing it in. Then screw all the way in, connect sensor and start the machine to circulate and fill of the new oil filter. Turn off and you will need to add additional oil again to level of dipstick with it resting on the threads. Wipe all areas and verify no leaks! Change annually both oil and filter.
curryd
Extremely easy. I agree, it takes about an hour to do it. Easy maintennance when prepping sled in the fall. Definitely change the filter. I don't understand how Yamaha says its okay to leave it. The filter is what keeps the oil clean. And I can't believe people are willing to pay a dealer an hour or more to change oil. Thats close to $100 without the cost of oil and filter.
enticeraised
curryd said:Extremely easy. I agree, it takes about an hour to do it. Easy maintennance when prepping sled in the fall. Definitely change the filter. I don't understand how Yamaha says its okay to leave it. The filter is what keeps the oil clean. And I can't believe people are willing to pay a dealer an hour or more to change oil. Thats close to $100 without the cost of oil and filter.
yuppers
hondavfr4ever
- Dec 1, 2009
- Minneapolis area, MN
- 08 FXNytro
Easy, do it yourself and save money! Just dont overservice the tank, or it will vent into the airbox and all over the front of the motor!
