piersol
Wife picked me up a filter today for my 07 Attak. Manual says to use 5GH-13440-20. The dealer gave her a 5GH-13440-50. She questioned him on it, he told her it is the same thing.
That just doesn't cut it for me. Is it the same filter with an updated number, or is it a filter for a different machine that "will work"?
piersol
a bit of searching on the net shows that this filter is most commonly used as a "marine Grade" filter. Boat motors use the number ending in 50.
So, do I install it? The dealer is an hour away, and my oil is drained. There is no snow here so I am not in a rush to finish, but I also don't like the idea of leaving the motor sit without oil.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
From my own googling, it seems to be a new superseded part number for the same filter and it appears in the cross reference with the old number.
http://www.yamahastarstryker.com/21-technical-discussion/14393-oe-oil-filter.html
http://www.oilfilter-crossreference.com/convert/YAMAHA/5GH-13440-50-00
If there are no physical differences, it's the same. Some have mentioned that Yamaha gave them the shorter -50 filter instead of another one which was supposed to be longer.
http://www.fjrowners.com/forums/9-fjr-technical/34714-yamaha-oem-oil-filter.html#post356186
piersol
Ok, thanks. I kind of found the same thing. Went to official yamaha parts site, it shows that the number changed but the new number is the same - 20 number lol. Must be a typo.
I'm going to go ahead and install it.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Is it physically the same as your old one?
piersol
Seems to be, yes
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Yes, the 5GH filter numbers have changed slightly in the last year or so.
The 13440-00 filter is now a 13440-30 and the 13440-20 is now a 13440-50.
The 13440-20 and 13440-50 are approximately a 1/4" shorter than the other 2 numbers
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
It's shorter and they probably charge just as much or more than before.
boostedyammie44
- Dec 3, 2013
- Fond du Lac
- 07 attak mpi stage one(sold) 15 viper ltx se soon to be boosted
Same filter it's superceded, there is a little difference on the inside by the o ring. Put it on!
piersol
filter is on, fresh Royal Purple 0w-40 oil in motor. Now to tackle the skid!
