Frank77
Can someone please tell me how to get to the oil filter, I want to change the oil and filter but not sure the best way to access the oil filter. Thank-you in advance.
Elton Buss
Check out the frequently asked questions section under fluids. Mr sled did a great post on the entire oil change. Have fun
Frank77
Thank-you!Check out the frequently asked questions section under fluids. Mr sled did a great post on the entire oil change. Have fun
Elton Buss
No need, Mr.sled and everyone on this site are the best.
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
It's kind of a booger to change an Apex oil filter the first time, as it's "down in there!" In a nutshell, you need to remove the hood, headlights, air box, battery, and battery tray.Can someone please tell me how to get to the oil filter, I want to change the oil and filter but not sure the best way to access the oil filter. Thank-you in advance.
This link is for a battery tray modification, but shows where the oil filter is located, once you get in there.
https://ty4stroke.com/threads/apex-...ake-oil-filter-change-a-little-easier.132380/
msgt van
First time, it's a bear...after that, just a couple of cocktails to get the job done!
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
I’ll add....Never understood why they put the battery down there. Terrible design
Frank77
Thank-youIt's kind of a booger to change an Apex oil filter the first time, as it's "down in there!" In a nutshell, you need to remove the hood, headlights, air box, battery, and battery tray.
Frank77
I also have been searching this site on how to change the Chain Oil but haven't bee able to put my finger on it. The first article with the oil change from Mr Sled is awesome I am hoping there is one for the chain oil too and it is just my inability to search. If someone could direct me to one I would appreciate it.
Redbeard
- Oct 14, 2011
- IN
There is a chain case oil drain screw located inside the tunnel, near the drive shaft. It takes a 12mm wrench to loosen. Just remove screw and go eat lunch. Install screw and refill. The rear suspension and track do not need removed to drain the chain case. The picture below is for reference on where to find the drain screw.I also have been searching this site on how to change the Chain Oil but haven't bee able to put my finger on it. The first article with the oil change from Mr Sled is awesome I am hoping there is one for the chain oil too and it is just my inability to search. If someone could direct me to one I would appreciate it.
When re-filling, I add 8.5 fluid ounces of regular 80/90 gear oil. Synthetic is great as well, but regular 80/90 is what I keep on hand.
This is also a good time to check chain slack. The adjustment screw is located just above dipstick. Loosen jam nut and and thread-in adjustment bolt until it stops, finger snug only! Back the screw out 1/4 turn and tighten jam nut. Finished!
Frank77
Awesome thank-you! This site is amazing! Just a question have you ever done it without removing the track? or impossible?There is a chain case oil drain screw located inside the tunnel, near the drive shaft. It takes a 12mm wrench to loosen. Just remove screw and go eat lunch.
When re-filling, I add 8.5 fluid ounces of regular 80/90 gear oil. I've done this every year for the past 11 years, with zero issues. Synthetic is great as well, but regular 80/90 is what I keep on hand.
Redbeard
- Oct 14, 2011
- IN
No, you don't need to remove the track or disassemble the chain case to change oil. Just feel around inside the tunnel, directly under the drive shaft, and you'll feel a small hex head bolt. It has a copper sealing washer under the head. That's what you remove, and the chain oil will drain right out. Don't get too carried away reinstalling. Just good and snug.
Frank77
Thank-you so much for your help!No, you don't need to remove the track or disassemble the chain case to change oil. Just feel around inside the tunnel, directly under the drive shaft, and you'll feel a small hex head bolt. It has a copper sealing washer under the head. That's what you remove, and the chain oil will drain right out. Don't get too carried away reinstalling. Just good and snug.
Frank77
I did everything you said and it went great, I have one more question if you don't mind the belt for my 07 Apex is this the right part number 8dn 176410?No, you don't need to remove the track or disassemble the chain case to change oil. Just feel around inside the tunnel, directly under the drive shaft, and you'll feel a small hex head bolt. It has a copper sealing washer under the head. That's what you remove, and the chain oil will drain right out. Don't get too carried away reinstalling. Just good and snug.
YesI did everything you said and it went great, I have one more question if you don't mind the belt for my 07 Apex is this the right part number 8dn 176410?
