..SNAKEBIT..
leaving for west trip and wanted to change oil so I order a filter local parts store, They crossed over the 5DM-13440-00 to a WIX 51358 the filter is a little longer
hugger70mtnmax
I used a napa gold 1365
Zakre
hugger70mtnmax said:I used a napa gold 1365
same as the wix 51365 , napa filters are made by wix, and this is a little shorter and easier to install then the one mentioned above.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
I read on here about a possible problem with a longer filter getting punctured if you where to hit a rock and bend something? Not sure on the details but just a heads up.
woodsrider
- Feb 17, 2005
- Lewiston, ID
- 2017 YZ450FX1 Moto-Trax 137 Mountain Kit
I don't think I'd put a longer one on. You take out the filter and you just toasted your motor.
Mountaintech
The 5DM-13440-00-00 is 2" long. If you run a longer filter in conjunction with the stock unaltered "engine protector" you are asking for trouble. Too many people now have found out the hard way.
hugger70mtnmax
Just to clarify I agree 100%. I am running the roest skidplate which gives more clearance and if something gets through that the oil filter will likely be the last of my issues.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Hugger, you are correct.
