Oil Filter
Is it easy to do the oil change on the Vector? I am putting a rear heat exchanger on and I figuired with 400 miles I would change the oil the also, the dealer said they would do the first ome if I would like, but for $350 all they do is grease it and change the oil. I might as well learn and save the money. Is there a thread that shows how?
Just remember that when you drain the oil there are two plugs to drain. One by the filter and the other under the oil tank. :flag:
