swmichvector
- Jan 27, 2009
- Clare, Michigan
- 2011 NYTRO
anyone find an aftermarket filter that is the same lenght as the yamaha 1 ?? or will the longer wix 51358 work??
theCATman
- Feb 19, 2007
- WI
- Yamaha
No aftermarket shorties that I know of.
Longer filters won't work in my '10 Vec LTX/GT. I'm assuming this is the case for the '08-'09 too, ever since the chassis switch?
A member on here did grind off some of the access door to get a longer filter on, but to me personally, I'm not gonna grind on a new sled just to save $8 on a stupid oil filter.
Yes, it's a joke that Yamaha has to A$$rape us $15 for a filter, but oh well, in this sport sometimes you gotta pay to play.
canadianhunter
HiFlow - #HF 147 is a short filter. My dealer uses them and also bought them at Royal Distributing for $ 8.95.
w8tn4snow
- Mar 28, 2008
- Upstate NY
- 2015 SR Viper LTX DX
Supertech ST6607 sold at good old Walmart , somewhere on here someone posted a link to a filter cross reference site . It read that most OEM filters are just bought from the lowest bidder . There was a breakdown of all the filters made that fit
Wix was on top if i remember but just barely , Supertech was second in quality but rated best buy since theyre a third the cost of the WIX ones .
i think the only physical difference was case thickness and the Wix only had it beat there by microns of an inch . For $2.50 compared to $15 for a
Yamaha filter it was a no brainer . Do some searching on here and you may come across that link .
erosled
So how does the $15 per year (at most) put people in the poorhouse? Unless you put some 30k miles on per year, there's no reason to change the filter other than for summerization.
Vectornut
- Nov 18, 2007
- Eden, Vermont
- RS Vector
What's wrong with the OEM Yamaha filter?
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
If there's nothing wrong with their oil filter then I assume you buy the slides, carbides, plugs, oil and everything else there too? Personally I'll save money wherever I can if the quality is comparable.
RX1Dragn
swmichvector said:anyone find an aftermarket filter that is the same lenght as the yamaha 1 ?? or will the longer wix 51358 work??
Fram PH6607 is the same lenght as the yamaha and 1/3 the cost of the yamaha filter
Eagle1
Here's my take:YammyRX1 said:If there's nothing wrong with their oil filter then I assume you buy the slides, carbides, plugs, oil and everything else there too? Personally I'll save money wherever I can if the quality is comparable.
Filter, 4qts. oil, 3 spark plugs, chain lube at the dealer= $70.00
Helping out my local dealer stay in business for when I need that last minute important part before a trip AND ALSO NOT having to go to Wally world=PRICELESS!
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
Good point.
But when I bought my first 4 stroke (used) I took it in for a seasonal tune up which was advertised at $289 because it was all new to me and I wanted some experts to give it a once over. They neglected to tell me that parts were not included so with taxes it cost me $410 to keep my dealer in business. Next time I'll just buy the parts and do it myself.
- 12K
