TWINRX-1
My buddys RTX has a big problem. Went to check the oil and it was low put some in to bring it to the right level. Took it out for a spin and came back to the garage and there was oil coming from the airbox drain. Opened the lid and there was about half a liter of oil in the box looks like its coming out of the intakes. Anybody know what it might be!
ATTAKED
Sounds like its over full! They only hold 3 quarts. How are you checking the level? The manuel states to remove dipstick, clean, then re-insert. DO NOT SCREW IN! Remove then check level! Hope this helps you out.
TWINRX-1
I know the right way to check the oil .I 've owned a RX-1 for the pasted 5 years. I warmed up his sled for a couple of minutes turned it off and check the dipstick it wasn't near the low mark
kotapug
TWINRX-1 -
You need to put your location, site rules ,Thanks
mulderdad
Who cares where his location is.
He is a yammy rider lookin for some help.
I thought members location was only mandatory when using the classified sections.
cheers,
Rick.
cheers,
Rick.
kotapug
Have seen other people post that in the forum I thought I would just help out if that is a rule did not know.So take it easy and help him then .
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
- 2018 Sidewinder Ltx LE 50th Anniversary
Last year someone posted a similar problem and thought he needed an expensive engine repair. It turned out he had the oil tank out of it and when he reinstalled it the rubber oil lines were crossed at the engine. After installing them correctly all was fine. Have you removed the tank or had the lines off lately?
